Capture Import
kovacika
Capture Import
Postby kovacika » 17 Jan 2018, 19:30
I built a show file in a stand alone version of capture, and imported it into the console version. While my console will control the lights found on my PC (the standalone capture) it wont control the lights in the imported file. Any ideas?
Re: Capture Import
Postby niclights » 17 Jan 2018, 20:13
Was the theatre saved as Atlas compatible (assuming you're using Titan 10.1. If it's 10.0 it should be Argo)?
Re: Capture Import
Postby Gregory » 17 Jan 2018, 22:41
How are your DMX outputs assigned? I believe Titan will expect the first line in Capture to correspond to the first line in Titan and so on for the other lines. Titan doesn’t use sACN or Art-Net to communicate with Capture internally so these settings will not be used.
kovacika
Re: Capture Import
Postby kovacika » 21 Jan 2018, 04:22
Derp, turned out to be user error in universe patching (artnet starts at 0, not one). Thanks guys!
