Titan Feature Requests
Re: Titan Feature Requests
Is there any updates coming for the iPad app? It would be useful to be able to open the playback window for an example.
Suggestion: provide user option for undo...
1 - switch off the function completely
2 - specify the number of undo steps to be recorded/available (and therefore limit the amount of memory Titan uses up)
- Add an option in the Record Softkey menu to choose between record all "recordable" fixtures or only the selected ones. Exactly the same option we can find in the Clear Softkey menu (All or Selected Fixtures). So we can record values only from some fixtures without having to clear the others.
It would be interesting to be able to test a personality in the personality builder and even better to havean alerte when/where a value is not good.
Enjoy your AVOLife
Stéphane
Enjoy your AVOLife
Stéphane
Hi.
Connect cue fade.
If you connect a cue rocorded on a button (not fader) to have the option selecting connect cue button+the playback recorded on the button and fade it in with the encoder wheels. ( similar to changing the active shapes with connect cue+shape)
This is a game changer on smaller consoles where faders are limited. To be able to record the front lights at full and just fade them to the desired intensity.
Connect cue fade.
Hey,
Implement on screen faders, so cues or scale masters stored in the playbacks window can be displayed as faders.
Henry
Henry
Could we have, when we copy a cue, a State option to have the same look on stage with both cues.
EX :
Cue 1 : Fix 1 @ 50% Fix 2 @ 75% Fix 3 @ 20%
Cue 2 : Fix 1 @40 % Fix 8 @ 15%
Cue : 3 Fix 2 @50%
Cue 4 = Cue 2
If for Cue 4 I copy Cue 2 with tracked values I will have :
Cue 4 = Fix 1 @ 40% Fix 2 @ 75% Fix 3 @ 20% fix 8 @15%
With State option I would have
Cue 4 = Fix 1 @ 40% Fix 2 @ 75% Fix 3 @ 20% fix 8 @0%
thanks
Enjoy your AVOLife
EX :
Cue : 3 Fix 2 @50%
Cue 4 = Cue 2
thanks
Enjoy your AVOLife
Find fixture when repatching
It would be interesting, when we are recording a cue, to create a mask using attribute key in Attribute Editor Windows. It would give us more flexibilities.
Enjoy you AVOLife
Best
Stéphane
Enjoy you AVOLife
Best
Stéphane
when we double click on wheel key @ it put the attribute that is connected to the wheel at full, as this is mostly interesting for dimmers and we can use the dedicated @ key for them, we can also use the on screen attribute button to put the connected attribute at full and it is not revealent to kickly put most of parameters at full, it would be more useful that the @@ action on the @ key of wheels put the "on stage" value of the attibut connected to the wheel in the editor.
Enjoy you AVOLife
Best
Stéphane
Enjoy you AVOLife
Best
Stéphane
I'd love having the possibility to send midi notes from a console.
Best regards,
ED
Best regards,
ED
the info column in the cue list is interesting, but it should be linked to another window where we could see the text in bigger, choosing the font size and color. Maybe having a column on the left with cue numbers, a bit like the setlist window. with the current cue highlighted.
Best regards,
ED
Best regards,
ED
in my opinion Timecode is lacking options such as "only fire cue when TC is running not if it's stoped or paused", "fire the nearest to the TC locator", "fire cue only if the TC value matches the trigger TC" "afterroll/freewheel option" "offset on incoming TC" "auto fire cue option", ...
Best regards,
ED
Best regards,
ED
Hi
Would it be possible to create shortcuts in the software? Like for instance, if you want to change a palette in a cue - hold that specific cue on the touchscreen for like 3 seconds and than change palette and EXIT or something similar. It would smooth things up. Just an idea.
Thanks!
Thanks!
In order to improve our feedback and communication with customers we are trialling a new service on our website. It will allow you to suggest features to be implemented in the software and give other users the ability to vote and comment on the suggestions.
https://www.avolites.com/ideas
For each new major version the top ideas will be considered for inclusion in that version. Whilst we will always try to include the top ideas there may be rare occasions when this is not possible.
This will replace this thread on the forum for requesting features however the rest of forum will remain open for questions, advice and support.
Users browsing this forum: No registered users and 108 guests
