Cue Only in Cue list tracking
Hi, is there a way to set the tracking in a cuelist standard on Cue Only. When i used this it always go back to global. Guido
Re: Cue Only in Cue list tracking
It is not possible to change the default tracking mode however you can disable tracking for an entire cue list under Playback Options. Alternatively if you use the syntax to record new cues you can type Record Cue/Connect @ to record a cue as Cue Only.
Users browsing this forum: Google [Bot] and 67 guests
