Hi all
Just a quick one that i am sure every one knows and i am just being a tool and missing.
For example: i have a parcan rig up, i create 5 different chases and record them in the shapes and effects window, i then create a sub-master with a BPM master 1, how the hell do i link my chases to the BPM master i have tried the normal way of doing it and nope wont let me link the 2 together, also i should be able to link all 5 chases to the BPM master 1 as i will only be using 1 at a time anyway.
Shapes and Effects
Magners1985
Re: Shapes and Effects
I'm assuming given the subject when you say 'chases' you mean shapes or effects.
I don't know what you mean by the 'normal' way but you assign speed masters to playbacks via [Playback Options] (note that the 'Shapes and Effects' window contains palettes and these cannot be assigned to speed masters).
Magners1985
niclights wrote:I'm assuming given the subject when you say 'chases' you mean shapes or effects.
cool thank you thats what i wanted to know,
Magners1985
so continuing on my train of thought now how do i control my movement in my [shapes and effects] window, just asking as i like to put colour movement in that window and would like to alter speed from time to time when busking
If you are using shape palettes you can connect the wheels to the shape in programmer:
Personally I would use playbacks rather than palettes. You then have a number of options:
- - CUE/CONNECT, SHAPE, (toggle shape to control as required), <enter>. The wheels will then connect to control the shape(s)
- - Connect to playback shape = CUE/CONNECT, SHAPE, (toggle shape to control as required), <enter>. The wheels will then connect to control the shape(s)
- Assign a speed master and then set this as the speed source in [Playback Options]/<playback handle>/[Effects]/[Speed Source]
- Toggle speed to the playback fader (if available) in [Playback Options]/<playback handle>/[Effects]/[Shape & Effect Speed]
