I change my old motherboard Rolacue for a 2004 version, after a LCD display probleme (resolve tanks for your help), I have a other probleme white the roller, i have only the playback page who is select when i switch on the desk. in program and run (normal and talkover) mode.
When i turn, the good page number is writing in LCD display (normal) and when i created memory, they are created in the good and different pages, the probleme is just in restitution playback. If you know what's append and have a solution thanks for your help.
Probleme update Motherboard Pearl Rolacue to 2004 (Borris3)
Le Mortauricain
Suite a un degat des eaux j'ai changer la carte mere de ma pearl première generation (Borris1) par une dernière generation (Borris3).
J'ai le probleme suivant, la page du rouleur de playback ne change pas lorsque je la tourne, je n'ai acces qu'au 15 playback de la page selectionner à l'allumage de la console. Pourtant lorsque je tourne le rouleau, les différentes et bonne page s'affiche sur l'ecran LCD, et lorsque je fait des memoires et des chaser j'arrive bien a les creer dans les differentes et bonnes pages que je selectionne, je ne rencontre ce probleme que lorsque je veux restituer ces memoires ou chaser.
Merci d'avance
Merci d'avance
Le Mortauricain
Here is the translation :
ps: steeve> t'es dans quel coin de la france ?
Due to a water flooding i had to change the motherboard of my first generation pearl (borris1) to a last generation one (borris 3).
I have the following problem : the playback rollacue page does not change when i roll it, i only have access to the 15 playback that were selected at the boot of the console. however when i roll the rollacue, the LCD show the correct page and changes accordingly. when i create memories and chases, i can create then in the different and correct pages that i select, i only have the problem when i need to playback the memories or chases.
thanks for all.ps: steeve> t'es dans quel coin de la france ?
