Been using keyframe shapes to get more interesting tilt and position+dim shapes than are available with the normal shape generator.
Is it possible to set the keyframe shape so that it's based around the current fixture position rather than the absolute values in each frame ? (i.e. behaviour similar to normal shape generator) I've explored this for a bit and it doesn't seem possible - just want to check that's the case.
Thanks,
John.
Key frame shapes - relative values
Re: Key frame shapes - relative values
No. I'm not sure how that could work given it relies on specific values in frames. The solution to this is probably a pattern editor for normal shapes instead.
