Recording Palettes from DMX output
Quidam
Postby Quidam » 28 Sep 2017, 12:05
Here's an interesting idea applicable on other systems (MA, Chamsys) but which is, if I'm not mistaken, not possible on Titan for the moment :
https://www.youtube.com/watch?v=mBlyK-JbLQU
Too long, didn't watch : the guy is creating positions palettes in minutes by applying a pan-tilt fx/shape on a very basic position (say, all movers on tilt 30%), stopping the fx with a speed/rate master, then recording the P/T dmx output values in a position palette.
As I suspected, trying to do the same in Titan results either in an empty position palette (when trying to 'snapshot' the running shape without P/T info in the programmer) or, of course, a palette containing the base position on which the shape is applied.
Stage recording doesn't do it either (and of course FX palette is not the point here) and I perfectly understand why this is the preferable default behaviour but, as you can see in the video, a 'true' output recording mode can come in handy.
So, is there a way to record the raw DMX output values in a palette or a cue ?
If not, I guess that's a proper feature request :)
Thanks,
Charles
Re: Recording Palettes from DMX output
Postby Gregory » 28 Sep 2017, 14:03
No, there is no function to record the raw DMX values. Effectively cues and palettes record the values displayed on the wheels and shape offsets get applied after that.
Users browsing this forum: No registered users and 68 guests
