If I run a cue that has color info (lights are yellow and blue) and I run a cue (flash button) that has white strobe, then when I release the white strobe, the lights remain white instead of changing back to the running cue that has the lights blue en yellow.
I recorded the cues in Channel mode.
What do I have to do, to let the static color cue override the white color after releasing the white strobe?
The white strobe cue has FX info (from the shape generator) and color info (white color).
Color reset cue
Re: Color reset cue
Set the release mask in the white cue to include colour via [Playback Options]/[Release] (you may also want to change the local or master release time).
