Hi guys,
Not sure if something has changed with cuelist and the shape generator in 10.1 or I'm just missing something.
So I'm on a Quartz running 10.1.
I create a pan saw using the shape generator with the spread of 1.
Store the cue in a cue list.
Change the spread to 2 or any other value (The movers start moving with the new spread)
Store the cue in the same cue list.
etc etc for how ever many spreads I want.
In 10.0 this worked great. Quick and easy to program. But now the cue list will only have the first cue's spread in all the cues.
My work around has had to be to clear the programmer after every stored cue and then start again.
Is this a bug or something I'm missing in 10.1??
Shape Generator not storing spread on cue list
Re: Shape Generator not storing spread on cue list
In both v10.0 and v10.1, when the same shape is recorded into subsequent cues of a cue list it will track the shape from the first cue. At present it does not take changes to shape parameters into account when deciding whether to track or not so therefore the spread will match the value in the first cue. The work around for this is to turn off shape tracking in the cue list which will stop it from attempting to track the shape, you can change this setting at any point even after the shapes have been recorded.
Thanks Gregory!
I'll give that a shot. I must have it turn off in my 10.0 version somehow.
Users browsing this forum: No registered users and 67 guests
