Thanks for the help.
niclights wrote:With the Usb stick inserted press the DISK button and then select [Load Show] from the softkey menu. You should then have a softkey option for [Internal Drive] or [Removable Drive]. If you select [Removable Drive] you should find your show listed on the softkeys. Does that work?
