Titan PC Suite 10.1 ST issue
hushhush
Postby hushhush » 30 Jun 2017, 19:44
All simulators except the Sapphire Touch seem to be working properly and the Sapphire Touch is what I need. The ST simulator opens but all that is there is the workspace windows and fader banks on top and bottom. No ability to program. What am I missing here? Please advise
Re: Titan PC Suite 10.1 ST issue
Postby Gregory » 30 Jun 2017, 19:50
When running Titan Simulator in Sapphire Touch mode you will require two monitors connected to your computer, for the left and right screens of the console. If you only have one monitor you will only get the left hand screen, the softkey menu is on the right hand screen.
hushhush
Postby hushhush » 30 Jun 2017, 20:01
Thank you, I knew I was missing something obvious!
hushhush
Titan PC Suite 10.1 ST issue simulator system mode
Postby hushhush » 10 Jul 2017, 02:58
Is there a way to get into systems mode (to assign masters) in the simulator?
Postby Gregory » 10 Jul 2017, 08:52
To hold down a button on the virtual panel you should right click on them, this will allow you to use the Avo+Disk key combination or you can use the keyboard shortcut Alt+Shift+S. On most consoles you can also assign masters from the Record menu (Alt+R).
Users browsing this forum: No registered users and 117 guests
