Masking Attributes on a Fader (Titan Mobile)
wirralmatt
Postby wirralmatt » 15 Jun 2017, 09:01
I am fairly new to this console, but have some lighting experience.
I have selected eight Chauvet Rogue Wash R2 fixtures and created a circle shape using the shape generator. I have saved this to a fader on my Titan wing.
I would like to change the settings of the fader so that the position and intensity are recalled, but the colour is unchanged from the current look - pretty much like I would want to do with a palette save.
Is this possible?
If so, how do I go about it please?
Matt
riscster
Re: Masking Attributes on a Fader (Titan Mobile)
Postby riscster » 15 Jun 2017, 09:17
You want the 'Record By Channel' mode. Then only things you touched since pressing clear will be recorded. Have a look at section 8 in the manual, page 181.
Postby niclights » 15 Jun 2017, 09:20
Prior to recording place only the attributes you want to record in the programmer and set the record mode to 'Record by Channel' (after pressing RECORD, toggle the option by pressing softkey A). The default record mode is 'By Fixture' which will record all attributes for any fixtures in the programmer.
Postby Gregory » 15 Jun 2017, 13:59
If you want to remove values already recorded in a cue you can use the Off function. This can be done in at least three ways:
  1. In the Programmer:
    1. Select the fixtures.
    2. Select the required attribute bank.
    3. Press the Off button.
    4. Press softkey C to turn off all attributes in that bank or sofkeys below for individual attributes.
    5. Press the Record button.
    6. Double press the cue button to merge new values.
  2. Off Playback Values:
    1. Press the Off button.
    2. Select the cue button.
    3. Select the attribute banks to remove.
    4. Press softkey D to update the cue.
  3. Cue View:
    1. Press Open/View button.
    2. Press the cue button to open the Playback View window.
    3. Press the View in the View Cue column. (You can also double tap the fader display at the bottom of the screen to get to this point.)
    4. Select the cells (or column header) for the values to remove.
    5. Press the softkey button for Off.
Technically these options disables the values allowing them to be turned on later if required.
Users browsing this forum: Bing [Bot] and 23 guests
