Hi there, I am using the v10 titan mobile, I have a dmx output problem, I have 10 rgbw Chinese par led with 8 chnl each, I already make the fixture and already patch it, I patch irlt into 4.1-4.9 and etc but I only can controk the first fixture, and the rest can not be control, they were juast strobing and moving around, but when I change the patch into 1.1 - 1.9 and etc, every thing is find, heelllpp plzzzz, is it my dmx output broke, how to fix it, it was also happens to my dmx 3, and for noted, I already set the dmx setting a line 1, b line 2, c line 3, d line 4
Thank you, and I waitting
Dmx problem urgent pkzzz
Re: Dmx problem urgent pkzzz
Check you have the latest software (V10.1) and the latest DMX firmware on you mobile. (USB Expert Console and see if there are updates available).
Then, in Titan in the Settings for Expert DMX try enabling 'Extra Stop Bit' that can help with fixtures with slight shaky receive circuits.
Are you certain the personality is correct? If Mark's suggestion doesn't help try patching as dimmers instead and see if the controls line up the way you expect.
I already try to pach with dimmer, still I have the same problem, know I already upgrade to v10.1 and update the firmware, and know my titan mobile can not connect, every time I plug the titan mobile, thwre is nothing happening, usually the blue led is running is it? And when I press the titan mobile program, it say doggle not found
It sounds like you've ended up with it stuck in boot mode. If you look in USB Expert on the left and side does it say something like 'Mobile Program Panel (Boot Mode)' if so select it and in the service tab on the right hand side select 'Exit Boot'.
I suggest you call either Avolites service or your distributor and they can talk you through the upgrade process on the 'phone.
Also there are instructions here https://www.avolites.com/Portals/0/Downloads/FAQs/FAQ10030.pdf which you could follow from step 2 onward.
I already press the exit boot button but nothing is happening, the mobile panel 217 (boot mode), I already press tye exit boot button, but nothing is
happening
happening
And at the status messages it say, mobile panel 217 entered boot mode, every time I push the exit boot button
With the panel selected on the left so to the Service tab and press the Program button. Browse to C:\Program Files (x86)\Avolites\UsbExpert\Panel Software and select m_mb.bin. Once the panel has finished reprogramming, Exit Boot and start the Titan Mobile software.
Ohhhh it works thankkk al ot man, but I have not test the dmx output yet, because right know all the power generator already shutdown, but at least ibgot my titan mobile back to live, once again thanks
