Arena V10 Shape issue
tmzmoz
Postby tmzmoz » 05 May 2017, 23:47
Were having a little bit of a problem with our brand new arena. When using the shape generator we cant edit or delete the running effects using the edit and delete buttons in the shape menu. The running shapes just dont show up and can only be removed using the clear function. This behaviour isnt replicated on either our titan mobile or our expert. any ideas?
Re: Arena V10 Shape issue
Postby Gregory » 08 May 2017, 12:03
Are you using the same show file on the Arena as the Titan Mobile and Pearl Expert? Does it happen from a new show with just 10 dimmers and a Dimmer Spread shape? Someone else has recently a reported a problem like this when using Handle Worlds, is this possible in your case?
clublights
Postby clublights » 08 May 2017, 20:24
Pretty sure this is the same user
Tom? That you ?
( this is Kade here )
Postby Gregory » 10 May 2017, 00:26
I did wonder whether it was the same however there wasn't enough to go on between the two reports to link them. I thought on balance it was better to reply to the post then potentially leave someone hanging.
clublights
Postby clublights » 10 May 2017, 00:27
Fully agree,
