Problem with shapes
phedias
Problem with shapes
Postby phedias » 07 Apr 2017, 08:57
Good morning all. Today I encounter a strange behavior from my console (Pearl tiger 2008) that I didn't experience before.
1) I select a fixture (7R beam moving head) and I locate the fixture.
2) I select playback a shape. I choose Tilt saw shape or circle shape or in general any shape that pan or tilt attribute are included in my shape. The shape is functioning properly the way is expected and I can even adjust speed and size.
3) Here comes the problem…….. I select “remove shapes from selected fixtures” and the shape stop as expected but then the console crashes and cannot do anything like exit or locate or whatever. So the software is not responding unless I power off and power on again the console.
- I already try with a different personality to apply pan and tilt shapes using other fixtures and still have the same problem.
- I already test the console with other shapes like color shapes that Pan /tilt is not involved and the shapes are working properly.
- I already delete a lot from the internal memory to free some internal memory (now internal memory display 91% free)
PLEASE HAVE A LOOK ON MY PERSONALITY BELOW (that I create myself) and let me know if the problem comes from there!
Or let me know if I have to reinstall the Shape file in my console. By the way I am running software v1.1 Vid version
; 'phedias beam-7R', 16 DMX Channels, filename: BEAM-WIN.R20
;  Copyright © Avolites Ltd. 2017
;   Date       By                Description
;   21-03-17   Phedias           Created
;   21-03-17   Pers Creator      Created - Exported from Diamond 4 file.
; The device name, upto 11 characters, no spaces are allowed
DEVICE  7R BEAM-WIN                            mode=Extended  16 DMX Channels
NAME "USER" "7R BEAM-WIN"
; The Type of instrument, 1 & M must required for backward compatibility
; The middle number denotes the number of DMX channels used
TYPE  1  16  M
; Mirror/Head resolution
MIRROR  2  540  290
;       |    |    |_______ maximum tilt movement (in degrees)
;       |    |____________ maximum pan movement (in degrees)
;       |_________________ 1 means moving mirror, 2 means moving head
; Patching Information. (Upto 10 lines allowed)
; Upto 10 lines of 159 chars are allowed including formulae
; Variables used d=dmx number(1..512), h=handle(1..60), n=devicename (11-char)
; Allowed modifiers
;   +,-,*,/,(,) basic arithmatic
;   % means remainder after divide
;   & means logical AND
;   | means logical OR
;   R means reverse the bits of the current result (operates on a byte)
;   ^ means logical Exclusive OR (operates on a byte)
;   > means shift to the right
;   < shift to the left
;   r followed by number means get the value of that parameter
;   d DMX address
;   n Fixture name, a 0 terminated character string
;   h The handle number
DEVICEADDRESS
"Handle  %2d"h
"Fixture %11s"n
"DMX     %03d"d
"Set to Extended"
DAEND
; Specify DMX limits
; minimum allowed dmx number
MINDMX=1
; maximum allowed dmx number
MAXDMX=496
; DMX number must be divisible by this
DIVBY=1
; DMX channel description
; 1. The channels bank number (1..20)
; 2. The upper faders in the bank (1) or the lower faders in the bank (61)
;    s=16-bit Fadeable LTP
; 4. DMX offset (1..number of DMX channels)
; 5. The output level is proportionally reduced by this level (0..100%)
; 6. The curve number (applicable only to HTP channels), usually set to 1
; 7. Inverted (I) or Normal (N)
; 8. Attribute type (A=Colour Wheel 1, B=Cyan, C=Magenta, D=Yellow,
;         E=Pan, F=Tilt, G=Iris, H=Dimmer, I=Gobo1, J=Gobo2, K=Gobo1 Rotate,
;         L=Focus, M=Gobo2 Rotate, N=Colour Wheel 2, O=Shutter, P=Prism, Q=Zoom,
;         R=Effect Rotate, S=Frost, T=Red, U=Green, V=Blue, 0=uncategorised)
;10. Attribute name, must be enclosed in quotes and upto 12 characters allowed
;11. The ON value of this channel (0..255)
;12. The Highlight level of this channel
;13. The Lowlight level of this channel
DMX
4     1   I    1   100   1N   A   1   "Colour"            0     0     0
2    61   L    2   100   1N   O   1   "Shutter"         255     0     0
1     1   H    3   100   1N   H   1   "Dimmer"          255     0     0
6     1   I    4   100   1N   I   1   "Gobo"              0     0     0
7     1   I    5   100   1N   P   1   "Prism"             0     0     0
7    61   I    6   100   1N   R   1   "Prism Rot"         0     0     0
9    61   I    7   100   1N   0   1   "Generic"           0     0     0
4    61   I    8   100   1N   L   1   "Frost"             0     0     0
6    61   I    9   100   1N   Q   1   "Focus"           127     0     0
3     1   s   10   100   1N   E   1   "Pan"             127     0     0
8    61   L   11   100   1N   E   1   "Pan Low"         127     0     0
3    61   s   12   100   1N   F   1   "Tilt"            127     0     0
8     1   L   13   100   1N   F   1   "Tilt Low"        127     0     0
9     1   I   14   100   1N   0   1   "Generic"           0     0     0
5    61   I   15   100   1N   0   1   "Reset"             0     0     0
5     1   I   16   100   1N   0   1   "Lamp"              0     0     0
END
TEXT
phedias beam-7R
Extended
INPUT fixture DMX No.
Press a Fixture
Select or Swop button
to make the patch.
END
ATTR
Function Obsolete
END
; Preset Palette Tables
PFTABLE "Pan/Tilt"   -1  10  12
"Middle"             21  7F  7F
"Left"               22  4F  7F
"Right"              23  B0  7F
"Top"                24  7F  4F
"Bottom"             25  7F  B0
"TLeft"              26  4F  4F
"TRight"             27  B0  B0
"BLeft"              28  4F  B0
"BRight"             29  B0  4F
PFEND
PFTABLE "Colour"     -1   1
"Open"                1   0
"Red"                 2   8
"Amber"               3  62
"Yellow"              4  1C
"Green"               5  26
"Cyan"                6  4E
"Blue"                7  12
"UV"                  9  3A
"Magenta"            10  44
"UV"                  8  3A
PFEND
PFTABLE "Gobo"       -1   4
"Open"               11   0
"Gobo 1"             12   5
"Gobo 2"             13   A
"Gobo 3"             14   F
"Gobo 4"             15  14
"Gobo 5"             16  19
"Gobo 6"             17  1E
"Gobo 7"             18  23
"Gobo 8"             19  28
"Gobo 9"             20  2D
PFEND
; Macros
; Range Tables
; Column by column description...
; 1. Low DMX value (inclusive)
; 2. High DMX value (inclusive)
; 3. Displayed text (max 11 chars)
; Variables used a=low val, b=high val, c=DMX val
RANGE 1  ;Colour
0   7    "Open"
8   17   "Red"
18  27   "Blue"
28  37   "Yellow"
38  47   "Green"
48  57   "Yellow"
58  67   "UV"
68  77   "Magenta"
78  87   "Cyan"
88  97   "Light Green"
98  107  "Amber"
108 117  "CTO"
118 127  "Pink"
128 137  "CTB"
138 147  "CTO 2"
148 149  "CT 3"
150 255  "Scroll %3d%%"(c-a)*100/(b-a)
REND
RANGE 2  ;Shutter
0   3    "Closed"
4   103  "Strobe %3d%%"(c-a)*100/(b-a)
104 107  "Open"
108 207  "Pulse %3d%%"(c-a)*100/(b-a)
208 212  "Open"
213 225  "Rnd St %3d%%"(c-a)*100/(b-a)
226 238  "Rnd St %3d%%"(c-a)*100/(b-a)
239 251  "Rnd St %3d%%"(c-a)*100/(b-a)
252 255  "Open"
REND
RANGE 3  ;Dimmer
0   255  "%3d.%d%%"(c-a)*100/(b-a),10*((c-a)*100%(b-a))/(b-a)
REND
RANGE 4  ;Gobo
0   4    "Open"
5   9    "Gobo 1"
10  14   "Gobo 2"
15  19   "Gobo 3"
20  24   "Gobo 4"
25  29   "Gobo 5"
30  34   "Gobo 6"
35  39   "Gobo 7"
40  44   "Gobo 8"
45  49   "Gobo 9"
50  54   "Gobo 10"
55  59   "Gobo 11"
60  64   "Gobo 12"
65  69   "Gobo 13"
70  74   "Gobo 14"
75  76   "Gobo 15"
80  84   "Gobo 16"
85  89   "Gobo 17"
90  129  "Scroll %3d%%"100-((c-a)*100/(b-a))
130 134  "Open"
135 170  "Scroll %3d%%"(c-a)*100/(b-a)
171 175  "1 Spin %3d%%"(c-a)*100/(b-a)
176 180  "2 Spin %3d%%"(c-a)*100/(b-a)
181 185  "3 Spin %3d%%"(c-a)*100/(b-a)
186 190  "4 Spin %3d%%"(c-a)*100/(b-a)
191 195  "5 Spin %3d%%"(c-a)*100/(b-a)
196 200  "6 Spin %3d%%"(c-a)*100/(b-a)
201 205  "7 Spin %3d%%"(c-a)*100/(b-a)
206 210  "8 Spin %3d%%"(c-a)*100/(b-a)
211 215  "9 Spin %3d%%"(c-a)*100/(b-a)
216 220  "10 Spi %3d%%"(c-a)*100/(b-a)
221 225  "11 Spi %3d%%"(c-a)*100/(b-a)
226 230  "12 Spi %3d%%"(c-a)*100/(b-a)
231 235  "13 Spi %3d%%"(c-a)*100/(b-a)
236 240  "14 Spi %3d%%"(c-a)*100/(b-a)
241 245  "15 Spi %3d%%"(c-a)*100/(b-a)
246 250  "16 Spi %3d%%"(c-a)*100/(b-a)
251 255  "17 Spi %3d%%"(c-a)*100/(b-a)
REND
RANGE 5  ;Prism
0   127  "Open"
128 255  "Prism"
REND
RANGE 6  ;Prism Rot
128 190  "Spin C %3d%%"100-((c-a)*100/(b-a))
191 192  "Open"
193 255  "Spin C %3d%%"(c-a)*100/(b-a)
REND
RANGE 8  ;Frost
0   127  "Safe"
128 255  "%3d.%d%%"(c-a)*100/(b-a),10*((c-a)*100%(b-a))/(b-a)
REND
RANGE 9  ;Focus
REND
RANGE 10  ;Pan
0   255  "%3d.%02d%%"(c-a)*100/(b-a),100*((c-a)*100%(b-a))/(b-a)
REND
RANGE 12  ;Tilt
REND
RANGE 15  ;Reset
0   25   "Safe"
26  76   "Reset"
77  127  "Reset P/T"
128 255  "Reset All"
REND
RANGE 16  ;Lamp
0   9    "Safe"
10  100  "Lamp Off"
101 255  "Lamp On"
REND
Reason: added code tags
Re: Problem with shapes
Postby niclights » 07 Apr 2017, 09:57
I am not familiar with this.
I'm not sure if it is related or even causes a problem but in your 7R personality the LSB controls for the 16bit attributes (ie. Pan Low and Tilt Low) should be allocated to bank and wheel slots 0 (ie. no slot as it is combined and allocated with its associated MSB).
For example:
0     0   L   11   100   1N   E   1   "Pan Low"         127     0     0
0     0   L   13   100   1N   F   1   "Tilt Low"        127     0     0
If that does not help then I see no harm in reloading the shape file (System/[Utilties]/[Load Shape File]).
Other things:
- Does this happen following a Wipeall?
- Does it work ok if you use DELETE/(toggle shapes for delete with softkeys)/<enter>/<enter>?
phedias
Postby phedias » 07 Apr 2017, 12:16
Thank you Nick. Solved out already. Problem was the Pan fine and Tilt fine. After i set both to 0 everything works properly!
Users browsing this forum: No registered users and 68 guests
