R20 to import in the personality builder
phedias
Postby phedias » 24 Mar 2017, 06:34
Hi guys. Is there a way we can import R20 file into the avolite personality builder edit it and then export again?
Re: R20 to import in the personality builder
Postby niclights » 24 Mar 2017, 09:05
There is but unfortunately there is a fault in the current version which causes an error.
However, usually this requires a lot of manual intervention anyway and, unless you are trying to convert to Titan and there are a large number of function ranges I don't think i't's worth it. Generally speaking if it's new or a complicated edit (for example adding ranges, palettes or macros) then I would start from scratch in Personality Builder and then generate .R20. For simple .R20 edits I would just use a text editor.
phedias
Postby phedias » 24 Mar 2017, 11:23
I am using classic pearl tiger and i already made some editing with text editor but i also need to edid the will mapping of the file. I guess i cannot do this with text editor. I believe i need to convert to D4 or do it from scratch is that right?
Postby niclights » 24 Mar 2017, 11:43
You can edit everything with a text editor. Personality Builder just makes some things easier such as function ranges and converting decimal to hexadecimal values for macros.
phedias
Postby phedias » 25 Mar 2017, 06:48
Thank you Nick! How can i edid the weel mapping by using text editor?(I don't see on R20 files a reference for weel mapping and that's way i am confused) Is that the first colum?
Postby niclights » 25 Mar 2017, 09:28
To repeat what I posted in your other thread:
It is the first two columns.
Column one is the attribute bank where 1-10 is the first page and 11-20 the second (ie. 1= dimmer on page one, 2= shutter on page one, 11= dimmer on page two).
Column two is the wheel where 1= wheel A and 61= wheel B.
Note that for the first attribute bank (ie. dimmer page 1) you can only assign to wheel A. Wheel B is invalid here. Maximum number of wheel slots 39.
phedias
Postby phedias » 25 Mar 2017, 10:41
very clear many thanks Nick
