Pro Presenter Midi Control
Is it possible to control lighting scenes on a titan mobile running v10 by using the midi controller built into pro presenter?
Re: Pro Presenter Midi Control
Would love to know if this is possible. Would be great trigger a lighting scene with a media cue in ProPresenter.
Based on the info here https://support.renewedvision.com/article/236-sending-midi-cues-from-propresenter, it doesn't look like there's any reason why it wouldn't work.
Note that you'd still need a MIDI interface to get the MIDI signal out of your ProPresenter machine and into the Mobile.
- sideshowbond
I don't know how ProPresenter works but you might wanna have a look at this:
http://www.avolites.de/support-downloads/midi-to-web
Midi to Web can translate midi notes to WebAPI commands which can trigger playbacks.
Helpful tools would be Loopbe as internal midi port and maybe MidoBome as midi to midi translator (although you most likely won't need that).
