Good Day
Apologies if this was answered already.
I want to know if is there a way to ''import'' triggers from one show to the other (the reason for this is I don''t want to set up my triggers every time I create a new show as I use the Alesis Q25 for Midi commands)
I did look at importing but I can not find it, I also looked in the individual folders but I can not seem to find the ''trigger'' folder
Please help!
Thank you in advance
Exporting Midi Commands (triggers)
clublights
Re: Exporting Midi Commands (triggers)
there is not
Triggers are not importable and only work on the console you made them on if you change consoles you will have to rebuild the triggers.
It's an oddity of triggers.
clublights
Work around ...
If your making hardware triggers make a base show with your mapping already done and always start your new shows from that ,,
