swop settings
wollsendk
swop settings
Postby wollsendk » 09 Jan 2017, 19:50
Hi
I have issue with my titan mobile running the latest titan software, It is about the swop function, where you can select all shapes and only intensity shapes, It works fine, even in the visualizer you can see that only intensity is affected, and pan/tilt are stilling moving when pushing the swop button, but sometime I have to shut down my console to move it another place, but when I have turned my computer back on and the show is loaded, It seems to ignore the "only intensity shapes setting", and all shapes are stopped. I have tried whit different fixtures.
The second, is also happing after a reboot. 6.4.2 Selecting a running shape to edit, I can not select a running pan/tilt to edit.
regards
lars
Re: swop settings
Postby niclights » 11 Jan 2017, 10:39
I can confirm both issues. All being well they should be fixed in the next version.
