patching problem
patching problem
Hello everyone.I am using a classic tiger and i am trying to patch a fixture. i receive the flowing message on the screen:patch failed device space used up hit exit.Any idea anyone?
Re: patching problem
Does this happen following a wipeall?
No. Actually i can patch fixtures that are already existing in my console"s cache.I just created a fixture personality in the avolites software, export it as R20 file and then import it in the console.Then i try to patch the fixture and there comes the problem!
If it works ok from wipeall it suggests a problem with the show but if you can post the code here I will take a look. Please enclose it in the 'Code' tags.
sorry cannot find that option how can i use code to att. for you the file?
Just open the .r20 in a text editor (ie. Notepad), copy all, then in your reply here press the 'Code' button at the top and then paste.
'china anthi2', 8 DMX Channels, filename: ANTHI2.R20
; Copyright © Avolites Ltd. 2017
; Date By Description
; 07-01-17 Phedias Created
; 07-01-17 Pers Creator Created - Exported from Diamond 4 file.
; The device name, upto 11 characters, no spaces are allowed
DEVICE anthi2 mode=Standard 8 DMX Channels
NAME "china" "anthi2"
; The Type of instrument, 1 & M must required for backward compatibility
; The middle number denotes the number of DMX channels used
TYPE 1 8 M
; Mirror/Head resolution
MIRROR 0 0 0
; | | |_______ maximum tilt movement (in degrees)
; | |____________ maximum pan movement (in degrees)
; |_________________ 1 means moving mirror, 2 means moving head
; Patching Information. (Upto 10 lines allowed)
; Upto 10 lines of 159 chars are allowed including formulae
; Variables used d=dmx number(1..512), h=handle(1..60), n=devicename (11-char)
; Allowed modifiers
; +,-,*,/,(,) basic arithmatic
; % means remainder after divide
; & means logical AND
; | means logical OR
; R means reverse the bits of the current result (operates on a byte)
; ^ means logical Exclusive OR (operates on a byte)
; > means shift to the right
; < shift to the left
; r followed by number means get the value of that parameter
; d DMX address
; n Fixture name, a 0 terminated character string
; h The handle number
DEVICEADDRESS
"Handle %2d"h
"Fixture %11s"n
"DMX %03d"d
"Set to Standard"
DAEND
; Specify DMX limits
; minimum allowed dmx number
MINDMX=1
; maximum allowed dmx number
MAXDMX=504
; DMX number must be divisible by this
DIVBY=1
; DMX channel description
; 1. The channels bank number (1..20)
; 2. The upper faders in the bank (1) or the lower faders in the bank (61)
; s=16-bit Fadeable LTP
; 4. DMX offset (1..number of DMX channels)
; 5. The output level is proportionally reduced by this level (0..100%)
; 6. The curve number (applicable only to HTP channels), usually set to 1
; 7. Inverted (I) or Normal (N)
; 8. Attribute type (A=Colour Wheel 1, B=Cyan, C=Magenta, D=Yellow,
; E=Pan, F=Tilt, G=Iris, H=Dimmer, I=Gobo1, J=Gobo2, K=Gobo1 Rotate,
; L=Focus, M=Gobo2 Rotate, N=Colour Wheel 2, O=Shutter, P=Prism, Q=Zoom,
; R=Effect Rotate, S=Frost, T=Red, U=Green, V=Blue, 0=uncategorised)
;10. Attribute name, must be enclosed in quotes and upto 12 characters allowed
;11. The ON value of this channel (0..255)
;12. The Highlight level of this channel
;13. The Lowlight level of this channel
DMX
1 1 H 1 100 1N H 1 "Dimmer" 100 0 0
2 61 L 2 100 1N O 1 "Shutter" 0 0 0
9 1 I 3 100 1N P 1 "Effect" 0 0 0
10 1 L 4 100 1N T 1 "Red" 255 255 0
10 61 L 5 100 1N U 1 "Green" 255 255 0
9 61 L 6 100 1N V 1 "Blue" 255 0 229
4 1 I 7 100 1N A 1 "White" 0 0 0
4 61 L 8 100 1N 0 1 "Amber" 0 0 0
END
TEXT
china anthi2
Standard
INPUT fixture DMX No.
Press a Fixture
Select or Swop button
to make the patch.
END
ATTR
Function Obsolete
END
; Preset Palette Tables
PFTABLE "Colour" -1 4 5 6
"Open" 1 FF FF FF
"Red" 2 FF 0 0
"Amber" 3 FF 7F 0
"Yellow" 4 FF FF 0
"Green" 5 0 FF 0
"Cyan" 6 0 FF FF
"Blue" 7 0 0 FF
"Purple" 9 7F 0 FF
"Magenta" 10 FF 0 FF
"Lavender" 8 B5 6D EF
PFEND
; Macros
; Range Tables
; Column by column description...
; 1. Low DMX value (inclusive)
; 2. High DMX value (inclusive)
; 3. Displayed text (max 11 chars)
; Variables used a=low val, b=high val, c=DMX val
RANGE 2 ;Shutter
15 255 "Strobe %3d%%"(c-a)*100/(b-a)
REND
RANGE 4 ;Red
0 255 "%3d.%d%%"(c-a)*100/(b-a),10*((c-a)*100%(b-a))/(b-a)
REND
RANGE 5 ;Green
REND
RANGE 6 ;Blue
REND
RANGE 7 ;White
REND
RANGE 8 ;Amber
RENDRe: patching problem
The first line should be commented out (ie. it should have a semicolon ';' at the beginning of the line). However, I think this is almost certainly just a copy/paste error here.
So assuming that's the case I can't see much wrong. But I wonder if it doesn't like the device name and/or the folder structure on the Usb stick. For the device name try adding 'UK' to the beginning (for example 'UKanthi2') and change the manufacturer name from 'china' to 'Unknown'. For the folder structure use Copy 2008. Instructions are included but all you need to do is unzip, place the .exe file in the root of your Usb Stick along with the .R20 and then launch the executable. This should create the correct directory structure and add the SG.DAT shapefile that is required.
Try those two things. If that works I would suggest changing white to LTP (currently it is set to Instant LTP) and the locate value for dimmer looks wrong at 100. Usually it would be 255 unless it is a combined dimmer/shutter control.
