TITAN ONE & ARKAOS
nospipi
TITAN ONE & ARKAOS
Postby nospipi » 23 Dec 2016, 16:52
Hey there.
Beginner here.i'm just trying to figure out some things on my new titan one.
Quick question :
Is there a way to run ARKAOS MEDIAMASTER in dmx mode from titan one software,working on the same laptop ??
Thanks in advance !!
yyy898
Re: TITAN ONE & ARKAOS
Postby yyy898 » 23 Dec 2016, 18:04
never did that but in theory it works like this:
in the dmx patch output the universe as artnet, to take that artnet signal in arkaos on the same pc you would need to use ip 127.0.0.1 and i think you would need a loopback adapter too.
google for loopback adapter too see how that works.
nospipi
Postby nospipi » 23 Dec 2016, 21:24
Thanks !
Anyone to put a little more detail ? Kind of noob here..
Postby niclights » 28 Dec 2016, 10:37
You don't need loopback adapter but you do need to ensure your machines IP is in the range 2.xxx.xxx.xxx or 10.xxx.xxx.xxx with mask 255.0.0.0. Typically most home routers are in the range 192.168.xxx.xxx with mask 255.255.255.0 and machines are set to get an IP automatically. Assuming that's the case you will probably need to go to your network adapter TCP/IP settings and temporarily change it to a static IP in the 2.xxx.xxx.xxx or 10.xxx.xxx.xxx ranges.
Postby icke_siegen » 29 Dec 2016, 11:00
It's correct that you don't need a loopback device - however, you need an active network link, e.g. the LAN cable plugged into another network device, or Wi'Fi connected to your router.
Users browsing this forum: No registered users and 85 guests
