Key Frame Edit Macros
kimwida
Postby kimwida » 15 Dec 2016, 17:23
I tried to make two macro to change speed of a key frame cue.
First macro
0. With opened effect editor window.
1. [Exit],[Clear],[Record],[Macro] and click a empty button in macros window.
2. Include the key frame cue to programmer.
3. Click and change speed to "10" in effect editor.
4. [Record], click the key frame cue and [Replace].
5. [Exit],[Clear] and [Record]
Second macro
3. Click and change speed to "30" in effect editor.
4. [Record] and click the key frame cue and [Replace].
They don't work. And I don't know what is wrong with these macros.
Re: Key Frame Edit Macros
Postby niclights » 15 Dec 2016, 18:20
As far as I can see it does not recognise the selection of the speed field. I'm not sure if this is technically a bug or just not implemented.
All I can suggest is to enable the speed on fader playback option or assign a speed master to provide a way to vary the key frame shape speed.
Users browsing this forum: Google [Bot] and 44 guests
