I used to save macros and use them well.
But after reinstalling Titan one, they don't stay in macro window.
When I create a macro and put it in macro window, it is good. I save it and exit Titan.
But after restarting Titan, the macro is gone. And it only shows in Show Libray Window and is "unsigned".
I tried to save a macro to Colours Window, the result was same.
I don't know why. What do I miss??
Well, it works in other PC. Maybe it is PC problem...
Improper ejection of USB may corrupt system. I soloved it by reinstall.
My macros don't stay in macro window.
Re: My macros don't stay in macro window.
I experienced the same Problem with Titan One V 10.0.
But I used a show programmed in V 9.1 and edited in 10.0.
So every time I restart the software, all my saved macros in the workspace window are gone.
Seems to be a bug?
Seems to be a bug?
In my case, it happened to me when I programmed a show in Windows 10 PC and opened the show in other Windows 7 PC.
Both use Titan One V 10.0.
I solved it through upgrading 7 to 10.
I just tried it again. Did a completely new show, safed 1x macro in the position window. Safed the show and restarted Titan One.
After the restart, evertyhing was in the playback windows except the macro. This must be a bug of V. 10.0
I am not 100% sure but it works to me.
Back up your shows before try this.
1. Empty "/user/document/titan/macros" folder or move your custom macro files to a safe folder.
1. Start Titan and open new show.
2. "Open Workspace Window"->"Show Library"
3. Check if there are your custom macros in "Unassigned Macros" tab.
4. If there are, delete them.
5. Restart Titan and check if there are STILL your custom macros in "Unassigned Macros" tab.
6. If there are still yours, I recommend you to reinstall Windows.
If not, open your shows. I hope you can see your macros in your macro window.
Users browsing this forum: Google [Bot] and 25 guests
