I was surprised this week to see my key frames being output to the stage as I was recording them, despite being in blind mode.
Is this a known issue?
Thank you!
v10 bug - Blind mode when recording key frames?
Re: v10 bug - Blind mode when recording key frames?
Just tried it and blind appears to working correctly with key frame shapes for me. A couple of things to note, you should enter blind mode before starting to create the key frame shape as the shape will be created in the programmer active at that time. The other thing is that Quick Palettes (palettes applied without fixtures selected) are treated as playbacks and will therefore output live even when blind mode is active (although they will not output at all while using Quick Build record mode).
