r20-d4
Re: r20-d4
You can load R20 files in Personality Builder which is installed as part of Titan PC Suite and then save a D4 file from that. Note that this will give a very basic personality which may not work very well with shapes and other desk functions. You may be better opening Personality Builder twice and creating the D4 file from scratch using the standard attribute and function templates using the original R20 file version as a guide. You can also export an R20 from a D4 file in Personality Builder however you will normally need to check the resulting R20 file in a text editor before use.
Re: r20-d4
it is its own file , there is no personality builder
Re: r20-d4
Personality Builder is an application for creating and editing D4 personality files for the Diamond 4 and Titan consoles. It is installed as part of the Titan PC Suite or can be downloaded separately from here.
Re: r20-d4
thanks for the help
Re: r20-d4
i've same question, but when i open, its show:
"a error occurred while attemting to load file, "XP-20R BSW 34DMX.R20". load file may be incomplete or corrupt. mode name cannot be empty.
what can i do in these moment? please advise, thank you
Re: r20-d4
Unfortunately this can be numerous things. One hint it gives you is 'node name cannot be empty' - so, open it in a text editor and enter a mode name.
If you want, you can send me the file by email (s.beutel@avolites.de) - I will have a look for you.
Re: r20-d4
I'd say another clue is in the filename which is not a valid length. Doesn't sound like a genuine R20 file to me
Re: r20-d4
Well spotted.
I mean the ACME XP20R BSW is already in the library: http://personalities.avolites.com/Main.asp?ID=200 - maybe Kennz should just update the personalities.
