Run 9.1 and 10.0
ljmartijnw
Run 9.1 and 10.0
Postby ljmartijnw » 26 Oct 2016, 16:46
Hello
Can I run a version of 9.1 and 10.0?
With the installing of 9.1 the installation program says everything is up to date so 10.0 still stays in place.
Reason I want to do this: My own console runs 10.0 but the console of a venue I work in runs 9.1, of course they have to update their console buts thats not up to me.
Re: Run 9.1 and 10.0
Postby Gregory » 26 Oct 2016, 17:27
On consoles when you upgrade to version 10, it will keep the previous version installed and allow you to switch between the two versions. On PCs you can only have one version installed, when a newer version is installed it will overwrite the existing version. If you need to downgrade the version on your PC you should uninstall the version you have first, reboot and then install the required version.
