Capture settings
- zahoorjury
Capture settings
It's always to approach Capture setting via open workspace window tab (F) , it will Good to have capture settings along other work space selection shortcuts at very left side of the Screen , How to creat that short cut ?
Re: Capture settings
1 - Close all other windows and place/size it where you would like it to recall
2 - View
3 - [Record Workspace]
4 - Toggle softkey D to [Record Visible Windows]
5 - Toggle softkey E to [Leave Other Windows On Recall]
6 - Touch an empty workspace handle
You can quick record workspaces by simply double-tapping on an empty workspace handle. When using this method the current settings from softkey's D and E in the Record Workspace menu will be used (note that in step 5 you might prefer [Remove Other Windows On Recall]). To delete a workspace shortcut first enter the View menu and then used Delete/double-tap handle.
2 - View
- zahoorjury
thanks Nic, and what about the ''G'' wheel , is it possible to create a shortcut to select visualiser parameter on wheel quickly .
thanks in advance.
thanks in advance.
- zahoorjury
hi thanks for your help and may be my previous question was confused, now i need to ask that ,
is it possible to create a short cut of ''G'' Tab to selection straight wheels to Visiualiser instead of toggle between LEVEL, FADE TIME and DELAY TIME . hope you understand Now . and
when i select Group and Palettes tab to open it, my Capture window which is on My SECOND window disappears , to view it again i have to select it by Opening ''F'' Workspace Window then Capture Visualiser , it is happening scince yesterday when i assign the playbacks window selection to workspace. any ideas about my both questions .
Regarding softkey G I understood your question but can't think of any way, sorry. It might be possible to add a factory macro to do this in the future.
For workspaces that is just how the factory 'Groups and Palettes' shortcut is setup. You could replace it with one with the setting [Leave Other Windows On Recall] or a workspace containing everything including your Capture window. Each workspace shortcut can store window positions/sizes/button sizes/pages etc. Lots of possibilities.
