Virtual Template
welby
Virtual Template
Postby welby » 10 Oct 2016, 00:53
Hi, I am a new user so please be kind :)
I have sucessfully created my first show which is great, but what I would like to have is a virtual template with just my sliders and pages on or a workflow page that does the same - the reason I ask is that I run avolites from my windows tablet and my eyesight is not that good - I would like to just point and click to change the shows.
I have seen other software do this whereby they have a seperate panel just for the different shows.
Any help in achieving this would be greatfullly received - or if anyone has a way of creating virtual panels, please let me know.
Thanks in advance.
Re: Virtual Template
Postby Gregory » 10 Oct 2016, 14:22
Sorry there isn't a function like this currently in the TitanOne software. For opening different shows you could try the following: browse to your shows folder, right-click on one of the show files and select Open With. If you browse for and select the TitanOne application and tick the box to always open with that application then every time you double click on a show file it will start the software with that show loaded. You could also create shortcuts to those show files on the desktop. Note that this will only work if the software is not already running.
welby
Postby welby » 10 Oct 2016, 22:25
Gregory wrote:Sorry there isn't a function like this currently in the TitanOne software. For opening different shows you could try the following: browse to your shows folder, right-click on one of the show files and select Open With. If you browse for and select the TitanOne application and tick the box to always open with that application then every time you double click on a show file it will start the software with that show loaded. You could also create shortcuts to those show files on the desktop. Note that this will only work if the software is not already running.
Hi Gregory,
I have found a solution by creating Macros and by having different macro pages I can group them together.
This works well on my 10 inch windows tablet.
Thank you for yor assistance.
