Adjust the capture window size
- zahoorjury
Hi all, I accidentally adjust the capture visualiser and capture visualiser setting at their minimum look , even I cannot get the tab button of adjustment in it , how to retrieve these windows to its mean positions
- Attachments
- image.jpeg (151.09 KiB) Viewed 7319 times
Re: Adjust the capture window size
With the window active (white title bar) press the View button the select softkey C Window Options and then again softkey C Size and Position. This should resize the window back to one of the standard quarter positions.
- zahoorjury
Using Titan one V10 capture visualiser,
Regards
A dimmer, patched in Titan in the traditional way, is represented as spot in Capture.
If you really need distinct Capture symbols for PARs then patch them in Titan as Generic Par 36, Generic PAR 56, Generic PAR 64. If you don't find these fixtures then you need to update your personality library.
I don't know of fresnels - but then, just patch them as dimmer channels
- zahoorjury
Kindly name a RGB LASER for the Capture in V10
Regards
Regards
As far as I know it is not possible to simulate DMX lasers.
The full version of Capture Atlas provides laser simulation from Pangolin & LaserAnimation controllers.
