What console to buy.......??
uriahdemon
Hi, I currently use Freestyler with a couple of midi triggers and am looking to upgrade to an Avolites console. Money is an issue therefore I cannot afford the top end consoles new. I was wondering if anyone can give me some advice on what console would be best to buy from new or the best secondhand options there are from your experience. Thanks
Re: What console to buy.......??
I always prefer to buy new, i have had a lot of troubles with second hand.
I would suggest to start with a titan mobile if your budget is low.
If there is enough budget a quartz is your way to go: compact, but with the power to drive upto 16 universes artnet or 4 universes dmx
uriahdemon
Thanks very much for the reply. I was actually looking at the Titan mobile with the wing. My understanding is that the access to 4 universes just allows me more fixtures within a 512 range for each..... or have I got that wrong......?? I do not have so many fixtures right now and can fit them all within one universe as I am doing with Freestyler. What is the problem right now is trying to get the Titan one software installed so I can at least get it up and running to see how I get on with it. I keep getting 'No Dongle attached'
You cannot use Titan One without a dongle. However, you can use the Titan Simulator and then select any of the consoles to simulate. This would normally be installed as part of the Titan PC Suite.
uriahdemon
AAAhhh thanks. I have that up now. So I am assuming that this where I can learn to use both the Titan One software but also want to see what the Titan mobile does with this as a controller .....???
You can select the console type to simulate from the Simulator startup splash screen. Titan one has all the controls embedded in the display. For all the other consoles there is a separate 'Virtual Panel' which emulates the various control surfaces including Titan Mobile.
uriahdemon
Thanks again. I do realise I am going off subject now but I have the Titan Mobile screen in front of me and trying to patch some fixtures. The manual says press softkey PATCH..... but I cannot find it.
The patch key for the Titan Mobile can be found on the virtual panel in the group of buttons above the keypad and page controls.
uriahdemon
thanks mate. I get this now, the virtual Titan Mobile software works in conjunction with the Titan One software .... I have read loads today but nothing tells you how the Titan PC Suite actually interacts....... THANKS AGAIN !!!!
