T1, Add objects & material in capture
zahoorjury
Postby zahoorjury » 04 Sep 2016, 02:09
Hi just download T1 demo version , while looking into capture visualiser I cannot found how to add Object like Stage , Truss , sound speakers etc. And how to adjust the things individually at x , Y or X axis .
Any body can tell ?
Regards
Re: T1, Add objects & material in capture
Postby niclights » 04 Sep 2016, 09:03
Currently the only element available is 'Box'. These can be used to create stage, floor and wall etc. Open 'Capture Visualiser Settings' then select the 'Stage' tab. Press the [+] button to add an element. Select the elements to open and ajust properties.
zahoorjury
Postby zahoorjury » 05 Sep 2016, 01:30
Thanks , but how can I adjust the X , Y or Z axis of a patched fixture ?
Postby niclights » 05 Sep 2016, 09:26
Select fixture(s), toggle wheels on softkey G until it reads [Wheels=Visualiser]. Then select position attribute group ([P] above the thumbwheels). The thumbwheels now control X/Y/Z position. You can page to orientation and rotation controls by pressing [P] again.
Jscmidt
Postby Jscmidt » 22 Jul 2023, 22:47
Are there now more objects available or is it still only a box?
