Color bump
yyy898
Re: Color bump
Postby yyy898 » 10 Aug 2016, 13:39
jsustrunck wrote:I understand, but when I press record it will end the macro and save it. So your last steps will not get into the macro.
when you press record the macro doesn't save / stop recording, it can be that the macro light stops blinking but ignore that, you are still recording.
Just to clarify, to record a macro press macro, record, and then select a location to record too.
If the macro light stops blinking but you didn't press the macro button to stop recording, just ignore it. Go on as you would and press the macro button when you ready to stop recording.
Everything should work fine then.
Davudius
Re: Color bump
Postby Davudius » 20 Mar 2023, 18:06
niclights wrote:Record a chase or cue list where the first step only contains the odd fixtures in white and the second step only contains the even fixtures in white. Then turn cue release on in playback options.
But how do I make it so it releases the colour values at the same time as intensity? I would love for the cue steps in the list to have fade mode 2 like a regular playback que.
Users browsing this forum: No registered users and 89 guests
