V10 suddenly not working with external Capture!
davidacker
Postby davidacker » 28 Jun 2016, 23:16
Hi all,
Had my V9.1 hooked up to my Capture before I updated to V10.
Now it wont work. It's streaming ACN, using the same showfiles as before and i still cant get it to work!
Running both programs on the same PC with the same network as before!
Any ideas?
Best Regards, David Acker
Re: V10 suddenly not working with external Capture!
Postby Gregory » 29 Jun 2016, 12:40
The network adapter settings have changed slightly in version 10, instead of picking a single adapter to output on you can select multiple. It might be worth going into DMX Settings to check if the current settings are correct for your configuration.
Do you have an active (connected) network adapter (wired, wireless or loopback) while running the software?
davidacker
Postby davidacker » 03 Jul 2016, 17:36
Nope. No adapters!
Postby niclights » 03 Jul 2016, 18:13
Any firewalls blocking the new application?
Have you tried unassigning/reassigning the nodes?
Does this only affect old shows or is it also true from a new show?
Postby Gregory » 03 Jul 2016, 18:25
I would expect that you will need at least one active network adapter to be able to output DMX. If you do not have any others, you should install a loopback adapter to use instead.
