Hi there
please advise exactly where one can connect the titan mobile to Ethernet. I will use a usb to Ethernet device but which of the two usb ports on the titan? i am trying to connect a showtec node 8 .
any help will be appreciated
thanks
titan mobile ethernet connetion
Re: titan mobile ethernet connetion
If your mobile has two USB ports then please use only the upper one. The bottom one carried an old dongle and is not supported any more.
This USB port is to connect the Mobile to a PC with the Avolites Titan software installed - the Mobile itself cannot do anything without a computer attached.
In order to output ethernet, you need to have a computer with a free network interface. In your example, please connect a USB-Ethernet adaptor to the computer.
thanks.. i will try this
