hello,
I'm runnning on titan mobile ( v9.1 ) I have ever use a bcf 2000 to play playbacks but it doesn't work anymore ( maybe since the v9.1 ? ).
For example, I record a dim at 100% on playback window, I assign it on a fader of bcf 2000 by trigger menu, but when I push the fader it does " 0% / 100% / 0% / 100% " and not a dim since 0% to 100 %.
It's the same problem if the playback is in mode 2 " fade on fader ".
Sorry for my english, I have made a vidéo wich is maybe more understandable.
https://www.youtube.com/watch?v=Gh4mvVWSSAw
Thank you.
Manu
midi trigger problem
Re: midi trigger problem
When creating the trigger try toggling the Trigger Type to Item instead of Hardware. The Action should be something like Set Level or Fire At Level to make the trigger act like a fader.
Thank you very much Gregory, it work !
trigger type item and action fire at level.
