r20-d4
tamas70
r20-d4
Postby tamas70 » 01 Mar 2016, 17:34
How can you convert r20 file from d4
Re: r20-d4
Postby Gregory » 01 Mar 2016, 17:40
You can load R20 files in Personality Builder which is installed as part of Titan PC Suite and then save a D4 file from that. Note that this will give a very basic personality which may not work very well with shapes and other desk functions. You may be better opening Personality Builder twice and creating the D4 file from scratch using the standard attribute and function templates using the original R20 file version as a guide. You can also export an R20 from a D4 file in Personality Builder however you will normally need to check the resulting R20 file in a text editor before use.
tamas70
Re: r20-d4
Postby tamas70 » 01 Mar 2016, 17:51
it is its own file , there is no personality builder
Re: r20-d4
Postby Gregory » 01 Mar 2016, 18:03
Personality Builder is an application for creating and editing D4 personality files for the Diamond 4 and Titan consoles. It is installed as part of the Titan PC Suite or can be downloaded separately from here.
tamas70
Re: r20-d4
Postby tamas70 » 01 Mar 2016, 18:06
thanks for the help
Kennz
Re: r20-d4
Postby Kennz » 04 Nov 2016, 07:37
i've same question, but when i open, its show:
"a error occurred while attemting to load file, "XP-20R BSW 34DMX.R20". load file may be incomplete or corrupt. mode name cannot be empty.
what can i do in these moment? please advise, thank you
Re: r20-d4
Postby icke_siegen » 04 Nov 2016, 08:15
Unfortunately this can be numerous things. One hint it gives you is 'node name cannot be empty' - so, open it in a text editor and enter a mode name.
If you want, you can send me the file by email (s.beutel@avolites.de) - I will have a look for you.
Re: r20-d4
Postby niclights » 04 Nov 2016, 09:29
I'd say another clue is in the filename which is not a valid length. Doesn't sound like a genuine R20 file to me ;)
Re: r20-d4
Postby icke_siegen » 04 Nov 2016, 14:20
Well spotted.
I mean the ACME XP20R BSW is already in the library: http://personalities.avolites.com/Main.asp?ID=200 - maybe Kennz should just update the personalities.
