TochOSC and Avolites
alstead
Postby alstead » 24 Jan 2016, 07:55
At the moment I am messing around with TouchOSC and given the possibilities of the program it would be handy if it could be integrated with the Titan software. The problem I encountered is that I can't find an OSC command list for avolites. I am working on a layout but couldn't code it.
Online I couldn't find a solid awnser if Avolites supports OSC at all.
http://hexler.net/software/touchosc
Greetings, Lars
Re: TouchOSC and Avolites
Postby Gregory » 26 Jan 2016, 21:46
Unfortunately OSC is not currently supported. It might not help you but MIDI Show Control is supported.
From the version 9.0 release notes:
There is now a factory trigger mapping for MIDI Show Control (MSC). The device ID can be set via the [MIDI] option in user settings. The following MSC commands are supported.
  • GO - Fire the specified Playback or Cue
  • STOP - Pause the specified Playback or Cue
  • RESUME - Un-Pause the specified Playback or Cue
  • LOAD - Set the playback level to full.
  • ALL OFF - Release all playbacks
  • RESET - Same as ALL OFF
  • GO OFF - Same as RESUME
The MSC device ID can be set in the users settings in the MIDI section. The console will always respond to the all call ID (7F).
