pan tilt invert on p2000 sim
swampy
Postby swampy » 31 May 2004, 13:00
does the pan tilt invert on the sim work, if it does tips for a dimwit would be appreciated. :oops:
Vincent
Postby Vincent » 03 Jun 2004, 07:36
Yes it works.
It can be accessed via this routine:
1. select the fixtures you want to invert
2. go to <PATCH> and press <PATCH UTILITIES> (softbutton F)
3. press <INVERT>
4. Select Pan & Tilt on the grey attribute buttons
5. Change with softbutton E or F the setting
The result can be viewed on the CRT monitor.
nic
Postby nic » 05 Jun 2004, 01:31
It does not work, unfortunately. Most annoying problem!
Dreamt
Postby Dreamt » 08 Jun 2004, 13:47
Vincent wrote:Yes it works.
3. press <INVERT>
But when i work with MSD not works, the fixture are with the same form, I don't apreciate any change, I have change it in MSD. :(
Angel Gutierrez Redondo
Light Designer/Lightning Engineer
The Show Must Go On
Users browsing this forum: No registered users and 114 guests
