I think Ive found a bug where a shape can be played from 'nowhere', meaning it isnt in the programmer or a cue.
Lets say:
Cue 1 is a circle from the shape gen which is recorded by channel, and the heads are red.
Cue 2 is then open white pointing at the floor, also recorded by channel, with 100 clears in between.
When you connect to Cue 1 and Go, itis correct. If you go to Cue 2, the shape remains although the lights do go white and center at the floor.
I have tried the obvious clear/exit stuff. Only when I exit the TSP mode completely and THEN press clear does the shape go away. I used a diamond 4 at the weekend where the exact same thing happened.
Is this a bug? certainly seems like one, since there is nothing I can programto get rid of it.
James
Possible Theatre stack bug - Pearl 2004
Users browsing this forum: Google [Bot] and 42 guests
