Help program a cue
Nicke Löfgren
Help program a cue
Postby Nicke Löfgren » 27 Dec 2015, 11:02
Hello
Is unable to program this !! :oops:
Have tried with lot of different things, "High Priority" "Release mask" "kill at zero", etc.
1: I have a MH cue with a position and red.
2: Want a new cue instance 2st MH goes to gitarplayer at solo and shall be white.
3: When I then "exit" from the cue'n I want it to default to the first / last before cue
Can anyone make a simple manual
Nicke Löfgren
Re: Help program a cue
Postby Nicke Löfgren » 27 Dec 2015, 11:03
oops
I have a Titan Touch :D :D
Postby niclights » 27 Dec 2015, 21:47
If the solo cue is a single playback then release will be the answer. If the solo cue is part of a cuelist and you are talking about tracking then set it to solo.
yanlingg13
Postby yanlingg13 » 15 Feb 2016, 01:42
You can try to change your cue (if its a single cue) to fade mode 3 (crossfade) under playback options
