Have control, but no beams
rlangaard
Re: Have control, but no beams
Postby rlangaard » 16 Sep 2015, 14:49
Thanks for a quick reply!
Tried that now, did nothing..
Any other suggestions?
Music & Lights
Postby Music & Lights » 16 Sep 2015, 15:47
maybe try inverting the 1 & 0
........from this
// Iris
ChanRef Iris
Vismode Value
UseBits 1 2 3 4 5 6 7 8
DmxOffset 13
Mapping 0 200 1 0
Mapping 201 225 1 1
Mapping 226 230 1 1
Mapping 231 255 1 1
End
to this......
// Iris
ChanRef Iris
Vismode Value
DmxOffset 13
Mapping 0 200 0 1
Mapping 201 225 1 1
Mapping 226 230 1 1
Mapping 231 255 1 1
End
Music & Lights
Postby Music & Lights » 16 Sep 2015, 15:56
Hi Nic,
Regarding my issue with my Color Imagination LED Spot 200.
I have sorted out all my initial issues of no visual beam, color, smooth rotating gobo visual.
Now I just have 1 major issue.....the iris is inverted !
when the real light is full open the visualizer is showing closed & the opposite happens when it is closed.
I know it is just the formula needs a re-write. Please can u help.
This is the manual parameter
0-191 (Max. Diameter to Min. Diameter)
192-223 (Pulse Opening Fast to Slow)
224-255 (Pulse Closing Slow to Fast)
The following is the .r20 formula.....
RANGE 14 ;Iris
0 191 "%3d.%d%%"(c-a)*100/(b-a),10*((c-a)*100%(b-a))/(b-a)
192 223 "Pulse %3d%%"100-((c-a)*100/(b-a))
224 255 "Puls %3d.%d%%"(c-a)*100/(b-a),10*((c-a)*100%(b-a))/(b-a)
REND
Awaiting your reply thanks,
Kind regards,
Alfie
rlangaard
Postby rlangaard » 16 Sep 2015, 16:01
That didn't help either..
But thank you very much for trying!
Music & Lights
Postby Music & Lights » 16 Sep 2015, 16:23
Hi rlangaard
what exactly is the problem with your lights visual?
Alfie
rlangaard
Postby rlangaard » 16 Sep 2015, 18:40
Music & Lights wrote:Hi rlangaard
Alfie
Hi Alfie
I have movement, but no beams.
Rune
Postby niclights » 16 Sep 2015, 19:38
I can't see anything obviously wrong. It might be an issue with the .r20 attribute types. Make sure there are no duplicates other than uncategorised (0).
Postby niclights » 16 Sep 2015, 19:53
Just seen your request in the queue so I will make a factory version anyway.
rlangaard
Postby rlangaard » 16 Sep 2015, 20:23
Hi niclights!
Will check the attribute types.
Thanks!
rlangaard
Postby rlangaard » 16 Sep 2015, 20:33
is this where i should look for duplicates?
not shure i understand this completely..
DMX
2 61 L 1 100 1N O 1 "Shutter" 34 0 0
1 1 H 2 100 1N H 1 "Dimmer" 255 0 0
0 0 s 3 100 1N H 1 "Dimmer Low" 255 0 0
10 1 L 4 100 1N B 1 "Cyan" 0 0 255
10 61 L 5 100 1N C 1 "Magenta" 0 0 255
9 61 L 6 100 1N D 1 "Yellow" 0 255 51
4 1 I 7 100 1N A 1 "Colour" 133 0 0
6 1 I 8 100 1N I 1 "Gobo 1" 2 0 0
7 1 s 9 100 1N K 1 "Gobo 1 Rot" 128 0 0
0 0 L 10 100 1N K 1 "Gobo 1 R Low" 128 0 0
6 61 I 11 100 1N J 1 "Gobo 2" 189 0 0
2 1 L 13 100 1N G 1 "Iris" 0 0 0
5 1 s 14 100 1N Q 1 "Zoom" 128 0 0
0 0 L 15 100 1N Q 1 "Zoom Low" 128 0 0
5 61 s 16 100 1N L 1 "Focus" 128 0 0
0 0 L 17 100 1N L 1 "Focus Low" 128 0 0
3 61 s 18 100 1N E 1 "Pan" 128 0 0
0 0 L 19 100 1N E 1 "Pan Low" 128 0 0
3 1 s 20 100 1N F 1 "Tilt" 128 0 0
0 0 L 21 100 1N F 1 "Tilt Low" 128 0 0
19 1 I 24 100 1N P 1 "FX 1 Adj" 128 0 0
END
Postby niclights » 16 Sep 2015, 21:29
Yes. That looks fine but seems to be missing some attributes?
rlangaard
Postby rlangaard » 16 Sep 2015, 22:15
Yes, it looks like it does..
But i have no idea how to add the missing ones.
I made the files by using the generate r20 files function in peronality builder..
Rune
Postby niclights » 16 Sep 2015, 23:09
I would guess that some of the attributes were not assigned to wheel slots. Check the Pearl wheel mapping before export.
rlangaard
Postby rlangaard » 17 Sep 2015, 00:41
That was the solution!
Thanks nic!
Regards
Rune
