Thanks for a quick reply!
Tried that now, did nothing..
Any other suggestions?
Have control, but no beams
Music & Lights
Re: Have control, but no beams
maybe try inverting the 1 & 0
........from this
// Iris
ChanRef Iris
Vismode Value
UseBits 1 2 3 4 5 6 7 8
DmxOffset 13
Mapping 0 200 1 0
Mapping 201 225 1 1
Mapping 226 230 1 1
Mapping 231 255 1 1
End
to this......
// Iris
ChanRef Iris
Vismode Value
DmxOffset 13
Mapping 0 200 0 1
Mapping 201 225 1 1
Mapping 226 230 1 1
Mapping 231 255 1 1
End
........from this
// Iris
ChanRef Iris
Vismode Value
DmxOffset 13
Mapping 0 200 1 0
Mapping 201 225 1 1
Mapping 226 230 1 1
Mapping 231 255 1 1
End
to this......
// Iris
ChanRef Iris
Vismode Value
DmxOffset 13
Mapping 0 200 0 1
Mapping 201 225 1 1
Mapping 226 230 1 1
Mapping 231 255 1 1
End
Music & Lights
Hi Nic,
Regarding my issue with my Color Imagination LED Spot 200.
I have sorted out all my initial issues of no visual beam, color, smooth rotating gobo visual.
Now I just have 1 major issue.....the iris is inverted !
when the real light is full open the visualizer is showing closed & the opposite happens when it is closed.
I know it is just the formula needs a re-write. Please can u help.
This is the manual parameter
0-191 (Max. Diameter to Min. Diameter)
192-223 (Pulse Opening Fast to Slow)
224-255 (Pulse Closing Slow to Fast)
The following is the .r20 formula.....
RANGE 14 ;Iris
0 191 "%3d.%d%%"(c-a)*100/(b-a),10*((c-a)*100%(b-a))/(b-a)
192 223 "Pulse %3d%%"100-((c-a)*100/(b-a))
224 255 "Puls %3d.%d%%"(c-a)*100/(b-a),10*((c-a)*100%(b-a))/(b-a)
REND
Awaiting your reply thanks,
Kind regards,
Alfie
RANGE 14 ;Iris
REND
Kind regards,
Alfie
That didn't help either..
But thank you very much for trying!
Music & Lights
Hi rlangaard
what exactly is the problem with your lights visual?
Alfie
Alfie
Music & Lights wrote:Hi rlangaard
Alfie
Hi Alfie
I have movement, but no beams.
Rune
I can't see anything obviously wrong. It might be an issue with the .r20 attribute types. Make sure there are no duplicates other than uncategorised (0).
Just seen your request in the queue so I will make a factory version anyway.
Hi niclights!
Will check the attribute types.
Thanks!
Thanks!
is this where i should look for duplicates?
not shure i understand this completely..
DMX
2 61 L 1 100 1N O 1 "Shutter" 34 0 0
1 1 H 2 100 1N H 1 "Dimmer" 255 0 0
0 0 s 3 100 1N H 1 "Dimmer Low" 255 0 0
10 1 L 4 100 1N B 1 "Cyan" 0 0 255
10 61 L 5 100 1N C 1 "Magenta" 0 0 255
9 61 L 6 100 1N D 1 "Yellow" 0 255 51
4 1 I 7 100 1N A 1 "Colour" 133 0 0
6 1 I 8 100 1N I 1 "Gobo 1" 2 0 0
7 1 s 9 100 1N K 1 "Gobo 1 Rot" 128 0 0
0 0 L 10 100 1N K 1 "Gobo 1 R Low" 128 0 0
6 61 I 11 100 1N J 1 "Gobo 2" 189 0 0
2 1 L 13 100 1N G 1 "Iris" 0 0 0
5 1 s 14 100 1N Q 1 "Zoom" 128 0 0
0 0 L 15 100 1N Q 1 "Zoom Low" 128 0 0
5 61 s 16 100 1N L 1 "Focus" 128 0 0
0 0 L 17 100 1N L 1 "Focus Low" 128 0 0
3 61 s 18 100 1N E 1 "Pan" 128 0 0
0 0 L 19 100 1N E 1 "Pan Low" 128 0 0
3 1 s 20 100 1N F 1 "Tilt" 128 0 0
0 0 L 21 100 1N F 1 "Tilt Low" 128 0 0
19 1 I 24 100 1N P 1 "FX 1 Adj" 128 0 0
END
Yes. That looks fine but seems to be missing some attributes?
Yes, it looks like it does..
But i have no idea how to add the missing ones.
I made the files by using the generate r20 files function in peronality builder..
Rune
Rune
I would guess that some of the attributes were not assigned to wheel slots. Check the Pearl wheel mapping before export.
That was the solution!
Thanks nic!
Regards
Rune
Thanks nic!
Regards
Rune
