Hi all,
i have an avo quartz and i have a lot of chases programmed.
I created a bpm master to set the speed of the chases and linked it to all of them.
The problem that i have is that the bpm master only changes the fade times of the chases. So when i set fade to 0 and delay to global the chase just start's going realy fast.
Is there a way to let the delay time listen to the bpm master ?
chase speed on fader
Re: chase speed on fader
Not that I'm aware of. Currently non-global times are absolute. Rate and BPM masters only control global times. It would probably make sense for rate masters to proportionally control non-global times. Not so sure about BPM.
Ok, but in the delay in collumn it says global so shouldn't it be able to be controlled by a bpm master ?
