USB midi pad with tiger touch?
chetan16in
Postby chetan16in » 03 Jul 2015, 12:53
I have numark orbit USB midi controller
tiger touch running 8.1 not detecting any midi input !
how to make it recognise with tiger touch?
Thank You.
Warm Regards,
Chetan Makwana.
Re: USB midi pad with tiger touch?
Postby Gregory » 03 Jul 2015, 14:16
Titan receives MIDI using the standard 5-pin DIN connector which can be found next to the DMX outputs on the console. Other types of connection are not supported.
JSSound
Postby JSSound » 07 Jul 2015, 19:55
Hello!
I wanted to do the same thing with Titan Mobile. My idea (I want to use a 64 Button Midi Controller) is the following device (got this tip in another forum):
https://www.amazona.de/test-iconnect-mi ... padiphone/
With this interface you can create some settings (use Midi from USB Port and forward to 5 Pin Midi connector). Then it works as a stand alone unit.
I ordered one device, I can let you know how it works.
Jürgen
danhoff
Postby danhoff » 07 Jul 2015, 20:21
Very interesting, looks like a possible good solution to this problem! Let us know how it works!
Thanks!
JSSound
Postby JSSound » 16 Jul 2015, 19:29
Good evening!
I just had a test run with the Titan Mobile and a Midi trigger pad.
The IConnect Midi works well without a need to set anything up. Just connect the USB device to the iConnect and the output from the iConnect to the Titan Mobile through a Din5 Midi cable.
Then I created all the links for Midi triggers.
Now my issue (but I think that is the same for all Midi triggers):
The Titan Mobile only has a midi input, no output. Therefore I do not see a feedback on the pad itself.
I only used it to connect it to 32 Flash buttons to fire colors, gobos etc. But you do not see a feedback on the device itself if for example a cue is active or not.
If you want to use that device be careful that it is the "old" iConnect Midi. All newer devices to not have this USB port any more if I see that correctly.
Best regards
Jürgen
