wheel mapping issue
PiXeL
wheel mapping issue
Postby PiXeL » 02 Jul 2015, 19:06
i have a new fixture (Cameo PIXBAR 500 PRO) and i would like to create a new fixture for the pearl 2010.
i have no problems with the RGB, strobe and dimmer attributes. But... there are also White, Amber and UV. I created the atributes but when i want to map them on a wheel. they all follow. so if i drag white to gobo, amber and UV follows. So i have 3 attributes on the same wheel.
can someone help? its quite urgent! :-)
kind regards
Tim
Re: wheel mapping issue
Postby niclights » 02 Jul 2015, 19:31
This is because they are conflicting in the Diamond 4 mapping. Go to the Diamond 4 tab and make sure everything is mapped and in a unique slot (ie. nothing in red). Then you will be able to separate them in the Pearl section.
PiXeL
Postby PiXeL » 02 Jul 2015, 19:59
thx a lot!
Users browsing this forum: Baidu [Spider] and 25 guests
