individual palette times
The release notes for v9 suggest that you can apply individual times on palettes. Can someone help with this? Can't seem to find/work out how to do it.
Re: individual palette times
Can you please explain in more detail exactly what you are trying to do?
I can't think of anything new to v9 other than a fix for remembering the setting to fire palettes with times.
The notes with the release notes show a picture with colour palettes with individual times. Yes you can set a global time but how do you assign an individual time on each palette..
Ah, I think you're talking about general Titan features page. IIRC times in palettes was added in v7.
Place time values in the programmer (either via wheel by toggling the wheel mode or enter numerically by pressing the TIME key) then record in a palette.
These can then be used as references in cues allowing quick changes to times across a range of cues if required or as a busking tool. When used in busking there is a key profile option to fire palettes with or without times.
Users browsing this forum: No registered users and 82 guests
