Hi!
Is there a way to import a chase from a disk into a show on the Pearl2004?
If so, how?
Thanx!
Chase into Show
It is to import from a PC.
Quote from 2004 Manual:
However, I have never understood the function. I don't think it was ever documented before.
Does such an application exist and if so how does it work?
F [Import Chase] – You can import a matrix chase created on an external PC application using this feature. To import a chase, insert the disk containing the chase you wish to import and select this option.
It was a custom update for LD Dave Gibbon and Darren Parker at DPL...
The whole thing is explained in a bit more detail here....
http://www.avolites.org.uk/avonews/pres ... e_park.htm
( I only know because we are all Sarfenders! )
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Ok - I thought the two were linked a little more intimately....
Oops - I meant the software and <import chase> NOT Gibbo and Darren.
(another one for the lawyers! )
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Users browsing this forum: No registered users and 78 guests
