PLayback
Synapse
PLayback
Postby Synapse » 22 Apr 2015, 19:14
Hi
New to Titan one, I am unable to get more than one playback or chase to play at once when assigned to different fixture groups. They cancel each other out and turn off other fixtures.
Still learning so any help would be appreciated, my knowledge goes as far as a Zero 88 but the school have updated!
Cheers
Re: PLayback
Postby niclights » 22 Apr 2015, 19:24
When recording cues take care with record mode and the programmer. When set to [Record by Fixture] it will record all parameters for all fixtures that have been selected since clear was last pressed. When set to [Record by Channel] it will record only parameters in the programmer.
You can review/remove/add later as required but this is the fundamental thing to understand. You should be able to find more information on this in the manual.
Synapse
Re: PLayback
Postby Synapse » 22 Apr 2015, 22:29
Thanks, problem solved!
