Anyone else noticing lots of off behavior when mixing in a cue with another containing keyframe shapes?
Current testing: I have a large group of generic rgb fixtures patched with an applied phased color key frame shape recorded to a handle. I have another handle with a static color recorded to all fixtures. When I bring in the static cue while the fx cue is running, the cue with the effect seems to phase reset as well as have a quick burst of data across all channels. When I bring the static cue to zero there is another quick burst of data across all channels and certain channels seem to remain merged with the output until I re-fire the handle with the fx cue.
I have verified the same results through real world fixtures patched to DMX output on Titan Mobile and artnet out of computer running Titan Mobile.
						V9 strange behavior when fading cues with key frame shapes
Re: V9 strange behavior when fading cues with key frame shap
Thanks for pointing this out. We will fix the issue before the final release
i had a simular issue.
i had some key frame shapes running across some RGB led battens in a cue within a cuelist on fader 1.
on fader 10 i had a static cue crowd blinder generic dimmers at full.
when bringing in the fader or hitting flash of the blinder cue on fader 10.
the keyframe shape on the led battens would wig out momentarily.
only on this one cue-list and particular Keyframe shape though.....
I have this same problem with key frame shapes playing back on some LED washes and 20 odd sunstrips programmed at full on a fader, if I push the fader up and bring it back down the key frame shape flashes and glitches out. The glitches happen when the sunstrip cue reaches the bottom and deactivates.
Joe
						Joe
