Titan V.9 Quick build bug
dejlig.person
When I try to do a quick build (chase or cuelist), only the last step is recorded as a single cue. Also in versions 7.x and 8.x the quick build function didn't record the selected fixture order.
Re: Titan V.9 Quick build bug
Unfortunately I cannot reproduce this. I have tried a number of tests.
(all from a new show in v9.0 RC)
Test 1:
- Manually select fixtures in a specific order
- Change colour mix values
- Record playback by channel
- Repeat so that we have three playbacks with three different colours and fixture orders
- Edit times for each playback 2sec fade, 50% overlap (so we can visualise the fixture order)
- Quick build a cuelist from the three playbacks
- Replay cuelist
= three cues with the three separate colours which fade in using the fixture order set.
Test 2:
- Same as above with chase but before playing back chase set chase playback overlap to 50% (chases have a 'global' overlap that defaults to 100%)
= three steps with the three separate colours which fade in using the fixture order set.
Test 3:
- Record some colour palettes
- Create a group with a specific fixture order
- Select group and quick build a cuelist using the colour palettes
- Edit times for all cues to 2sec fade in, 50% overlap
- Replay cuelist
= three cues with the three separate colours which fade in according to the order set in the group.
Test 4:
- Record some colour palettes with times (2sec fade, 50% overlap)
- Select group and quick build a cuelist using the colour/time palettes
- Replay cuelist
= three cues with the three separate colours which fade in over 2 sec according to the order set in the group.
If you can post detailed steps to repeat the problem I will investigate further.
Test 1:
- Replay cuelist
Test 2:
Test 3:
- Replay cuelist
Test 4:
- Replay cuelist
Users browsing this forum: Baidu [Spider] and 25 guests
